#2 (permalink) | |
Name: Stephen Leworthy |
yeah, just make the line renderable but if you want it to be a real 3d model,
1. create a line with a number of vertexes on it and make it not streatch by move some vertexes in any x/y/z directions. copy the line (by segment/spline sub object), may be 2 -3 time and adjust their vertexes again (make it seam less). 2. make renderable and give the thickness and segment = about 12 and copy those 3 to be 6, 9 and..... 3. convert to poly and use noise modifier 4. use optimize modifier on the line these lines will look OK if you don't move the camera too closed to them. |
Name: travis schmiesing |
maybe make a swooping spline, extract it 4 or 5 ft.. make a tansparency map that has 4 lines on it, or however many lines you want, map onto extracted swooping spline. 4 electric lines for the polygon count of 1.
travis schmiesing |
| Electric Utility Building | Josh | Finished Work | 8 | March 15th, 2004 06:44 AM |
| Electric Bldg. | Josh | Work in Progress (WIP) | 4 | March 8th, 2004 10:50 AM |
| Electric Image Users in Australia | metier3 | General Discussions | 0 | May 4th, 2003 12:14 PM |
