Name: Carl Olson |
has anyone had any luck making a good, "shiny" copper? i have a project coming up that's going to have a copper roof and flashing, and i can't seem to get the material right. i've searched the forums, tutorials, etc, and haven't seen anything that helps. if anyone has any suggestions, i would greatly appreciate it.
thanks! oh, and i'm using viz, if that helps.
"If there's anything more important than my ego, I want it found and shot immediately." -Zaphod Beeblebrox, Hitchhiker's Guide |
Name: Robert Capper |
Maybe if you post where you are up to so far with the material along with a screeenshot of it in your scene it will be easier to see how to improve on it.
http://www.turntool.co.uk |
I thought I had an example of a copper roof I did once, but I guess I lost it...
Something that worked well for me was to use your main copper color that you want - just a solid color. Add a small amount of reflectance to it. Then, what gave me the best results was to add some sort of fluffy clouds map in the diffuse slot. Then I turned that down so slightly that you can only see a hint of it in the material. So when you render it, it doesn't look like a map of clouds in the copper, but looks like reflection, and variation in the copper itself. Just play with UVW mapping until you find something that looks right. |
Name: Carl Olson |
thanks for the advice! i'll play around with it a little more and post my efforts later. unfortunately, i've been sidetracked by other (more pressing) jobs for the day. the copper is for a project that i won't be seriously into rendering for a few more weeks; i'm really just planning ahead so i don't end up scrambling to make something work at the last minute. as far as the patina goes, i think it's going to be a bit of a "before" and "after" thing...i don't think we're going to use a pre-aged copper to start out with. and i'm pretty happy with my patina settings.
as a side-track, is anyone here familiar with the type-variant house by vincent james? i would love to see that place in about 15 years...what a beautiful building. anyway, thanks again. timmatron, i'll give that a shot as soon as i can, and post what i end up with.
