Autodesk VIZ Autodesk VIZ
Old July 15th, 2004   #1 (permalink)
Default Missing DLL Dialog Box
When opening a file in Viz 4 (has only been opened on Viz4) a dialog box comes up with:
Missing DLLS : FileName: boolcntrl.dlc Class: Boolean Controller. THis does not happen in the startup file when opening Viz
Is there a way to remove this? Is there a function in Viz like AutoCAD that I can "Wblock" the file out?
I have tried merging the file into another drawing, but the missing driver box pops up too.
Thanks for any help.
Arkitec
Arkitec is offline
Old July 15th, 2004   #2 (permalink)
Default Re: Missing DLL Dialog Box
I don't know if you how you can remove that missing DLL pop-up, but was the file created in another program where it used that particular boolean controller that your Viz 4 program doesn't have? I found that downloading a model created from another program but can be imported or opened in Viz4 sometimes have plug-ins or something Viz doesn't have installed that opens with errors. I don't know the way around it. It would be nice to know though...
Buffalo Bills is offline
Old July 15th, 2004   #3 (permalink)
Well the file was imported into Viz by 3ds created in FormZ; however, I havent had any problems doing this....ever.....Since the import into Viz, I havent had any problems.
I tried to "repair" viz from the install disk and that didnt help. I havent imported anything since this box came up either.....
Any thoughts on "wblocking" the file out....is there a script out there or something that you know of?
Thanks for the speeding response.
Arkitec
Arkitec is offline
Old July 15th, 2004   #4 (permalink)
abicalho's Avatar
The Bool Controller does not exist in VIZ 4. It's a new feature in MAX 5.
To remove it, you need to find it and you then need to substitute it with an existing controller.
But this file did come from 3dsmax.
Alexander
abicalho is offline
Old July 15th, 2004   #5 (permalink)
abicalho,
I did a search on my harddrive and did see it in my max5 directory. However, I never opened the file in max...So, how do I substitute the driver....? If I remove max 5 from my system should that fix it?
Thank you for any help...
Arkitec
Arkitec is offline
missing camera correction feature gail 3ds Max 4 June 3rd, 2004 12:05 PM
Quick Question - Rendering Dialog Box MegaPixel 3ds Max 8 June 18th, 2003 01:24 AM
Crop Box when I go to Render? Eric Autodesk VIZ 6 November 13th, 2002 12:48 AM
