Autodesk VIZ Autodesk VIZ
Old July 19th, 2004   #1 (permalink)
Default shadow parmeters
i have problomes with shadows with vray.
anyone can help how do i get soft shadows like with skylight?
i attached 2 images 1 with skylight and another one with vray.
randigi is offline
Old July 20th, 2004   #2 (permalink)
anvaraziz's Avatar
Default Re: shadow parmeters
go to v-ray environment n turn on override max's..
ply with the multiplier n color ..
try this one........i dont know much bout v-ray.. but i think this ll help u.....
im not sure this way is best or better...
anvaraziz is offline
Old July 20th, 2004   #3 (permalink)
already try it it dosent work
but thanks
randigi is offline
Old July 20th, 2004   #4 (permalink)
kippu's Avatar
well if you are talking about the shadow being dark ...you can play with the color mapping ( linear ...increase dark multiplier ) or
you can move the secondary bounces a little bit more
kippu is offline
Old July 20th, 2004   #5 (permalink)
well im tallking about the good shadow resolt you get when you put skylight
you can see the image have depth betwen objects.
attached the images so u can see.
randigi is offline
Old July 20th, 2004   #6 (permalink)
kippu's Avatar
strange ....can u show more settings like what light you are using and other parameters ...
kippu is offline
mystery shadow? TjQs Work in Progress (WIP) 6 March 23rd, 2004 04:06 AM
Shadow + Radiosity ? muzzy 3ds Max 1 November 16th, 2003 07:59 AM
Render Elements - Shadow muzzy 3ds Max 5 October 25th, 2003 03:47 AM
2D tree with shadow carlos_7 3ds Max 5 September 6th, 2003 07:32 PM
Shadow mask passes... Andy Lightscape 2 June 5th, 2003 09:33 AM
