Autodesk VIZ Autodesk VIZ
Old August 4th, 2004   #1 (permalink)
illyrianeye's Avatar
Name: Beni Ecen Vete
United_States  Send a message via AIM to illyrianeye
Default Autocad modeling
Hey guys, I am sure this has been questioned and answered in the past but here it goes again.
I am an Autocad modeler, who renders in Viz or max. However, sometimes i have trouble with the geometry that I import. In other words, when I bring a square box from autocad, I cant round its corners in viz as compared to doing it in viz by adding more vertices and bending or rounding the corners.
The other question is, whats the best way to import autocad geometry? what settings should I use.
Thanks for any info.
illyrianeye is offline
Old August 4th, 2004   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Autocad modeling
i import using the 3DS format. i too model in autocad, but if i have (in your example) a box i may want to chamfer or amend in this way in max, then i'll modell it in max.
when you import from acad you in effect import editable meshes and not primatives. so treat these meshes as you'd treat all other max editable meshes.
STRAT is online now
Old August 4th, 2004   #3 (permalink)
joske's Avatar
Name: Philip De keersmaecker
Belgium
donnow if this might help but :
DON'T
try to make yourself life easy and make your workflow alot quicker by modelling all in max/viz, it might take you a while to get used to it, but on the long term you will benefit.
i allways cleanup the acad files (text and hatches and all...) then import the 2D in 3D positions convert to spline (quicker snap) and then model from there
once you get the hang of it, it will speed things up alot! even more when your client wants to move around windows and door and such
(just don't use boolean in max/viz, that won't work)
joske is offline
Old August 4th, 2004   #4 (permalink)
kicks's Avatar
Name: patrick deno desamparado
Philippines
<your question it seem, is not technical issue(settings) nor errors in importing(which i presume you know well) but rather of convenience in editing imported objects.
<so for this i have no direct answer except to remodel the object again in autocad. For importing selected objects, I usually make "wblock" of it.
kicks
IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER.
kicks is offline
Old August 4th, 2004   #5 (permalink)
jysngltndz's Avatar
Name: jayson giltendez
Philippines
3ds to import.. editing mesh will also work, but if you purely model from cad,
much better if you fillet/chamfer your solids first before exporting them to viz..theres no better software each has its own diff purpose, it is where your comfortable working with that matters...
jysngltndz is offline
Old August 4th, 2004   #6 (permalink)
Peru
I use Autocad (ADT) for modeling..but now my main software is Sketchup
I can work much faster now...try it!!!!
Fernando Lino is offline
Old August 4th, 2004   #7 (permalink)
trhoads's Avatar
As mentioned, model in the program you are comfortable with. I too model everything in AutoCAD, and then link the file to my VIZ file. Under Utilities, the File Link Manager will allow you to link an AutoCAD file to VIZ. You can also update this file with a reload if changes are made. This works well for me. Hope it works for you.
trhoads is offline
Old August 4th, 2004   #8 (permalink)
I too model only in Autocad and use the import . DWG feature or I use the file link manager.
As for rounding the corners off I would do it in autocad.
graphix
graphix is offline
AutoCAD vs 3ds Max modeling ? muzzy 3ds Max 22 October 4th, 2006 05:43 PM
spline modeling in C4D through AutoCAD lines Bhanu Cinema 4D 7 November 27th, 2004 02:09 AM
Modeling: Selecting single objects on one layer coming from AutoCAD into MAX Jet 3ds Max 4 November 5th, 2003 08:08 AM
AutoCAd modeling vs Max Modeling muzzy General Discussions 4 September 18th, 2003 08:56 AM
Modeling in Autocad for Lightscape Sebree Lightscape 2 July 15th, 2002 08:57 AM
