Autodesk VIZ Autodesk VIZ
Old August 10th, 2004   #1 (permalink)
badpixel's Avatar
Name: Carlos Alberto Martinez
Mexico
Default radiosity can be applied to exteriors?
does radiosity can be applied to exteriors?...........or is only for interiors.
`cause im working on an outside scene, and just to process the radiosity of the streets and sidewalks alone takes an eternity.
settings: 85% quality
5 refine intinerations
5 filtering
radiosity meshing size 0.50 meters
thanks for your help!
badpixel is offline
Old August 10th, 2004   #2 (permalink)
chuck's Avatar
Default Re: radiosity can be applied to exteriors?
sure, radiosity works for exteriors. i'm assuming you are using Max right?
if you dont want to work with processing radiosity and all the settings, try out the global illumination. all you have to do is put a skylight in your scene and enable light tracer instead of radiosity. the skylight adds those nice soft shadows. adding a spotlight to simulate the sun will give you the combination of direct and indirect lighting, giving the rendering a lot more life....
chuck
chuck is offline
Old August 10th, 2004   #3 (permalink)
badpixel's Avatar
Mexico
WITH GLOBAL ILUMINATION YOU MEAN THE CHECKBOX IN THE IES SUN LIGHT "USE GLOBAL SETTINGS"????NOT SURE WHAT YOU MEAN
badpixel is offline
Help with Radiosity Image 6 Degrees Work in Progress (WIP) 3 July 22nd, 2004 06:59 PM
Radiosity Bret Bullough Autodesk VIZ 5 October 3rd, 2003 12:24 PM
SImple Radiosity Scene Setup MegaPixel 3ds Max 8 July 29th, 2003 08:17 AM
How to turn off Radiosity??? Aaron Autodesk VIZ 3 July 28th, 2003 12:34 PM
radiosity setting... crazy homeless guy 3ds Max 2 June 3rd, 2003 01:45 PM
