Name: James Taylor |
hi,
i'm trying to render an animation but after each frame i get an 'Image I/O Error' message appears. In the massage it states the path which i'm trying to save to and says memory error. I'm given the option of retrying or cancelling. Retry does nothing but if i cancel the application stays open and i can then manually save the frame to the hard drive? Obvisiously this is not ideal when each frame is taking approx 10min to render and there are 650 to do. i've tried searching in google for the error message but can't find any direct matches. I hope somebody will be able to help as i'm about to start crying!! Thanks in anticipation. James |
Name: Jason Matthews |
I have seen the message before, but I can't remember why it shows up. Try changing your settings in the file you are saving. If you are trying to save to .mov, try .avi. If you are trying to save as mpeg4 try to save as mpeg2.
Good luck.
Jason Matthews |
i got this msg before, and i change the save path to other drive and make sure your slave running in the same max version, cause last time i used my collaque machine which run in r5 and iam using r6, so the backburner conflict, after i upgrade the software, no more problem appears.
hope it helps
Beyond your Imagination :: www.geocities.com/wimpy_l :: |
Name: Jennifer O'Connor |
You are saving to single frames, and not using backburner, correct? You are saving this to the exact same location, in the exact same format, and it works manually but not automatically? Strange, indeed.
Have you solved your problem yet? Checking foler write-permissions, or trying a different folder or drive, or trying to write to a different image format are good places to start.
Jenni www.4DA-inc.com Chicago 3ds Max / Maya UG www.max3ds.com Render UG www.Render-Art.com |
| Network Rendering Problem | Maxer | 3ds Max | 23 | July 22nd, 2004 10:39 AM |
| rendering problem | Monty | General Discussions | 1 | July 8th, 2004 01:37 AM |
| exterior rendering problem | opang | Work in Progress (WIP) | 10 | September 2nd, 2003 01:35 AM |
| Lightscape Rendering problem..? | Richard McCarthy | Lightscape | 5 | June 13th, 2003 07:50 PM |
| problem rendering animations w/brazil | schmoron13 | 3ds Max | 3 | February 6th, 2003 05:44 AM |
