Autodesk VIZ Autodesk VIZ
Old August 11th, 2004   #1 (permalink)
Default Hidden Line
Does anyone know how to do a hidden line render of a scene in VIZ??? There is a wire frame option in the render scene dialog box, but it gets very confusing if there are more than a few solids.
Athena is offline
Old August 11th, 2004   #2 (permalink)
Saturn's Avatar
Default Re: Hidden Line
There is really no way to do it that I am aware of. I believe there is a plugin that will work. I could be wrong.
Jason Matthews
Saturn is offline
Old August 12th, 2004   #3 (permalink)
Richard McCarthy's Avatar
I am not sure how VIZ 2005 work, if it's the same as MAX 6 with Mental Ray integration, you can use mental ray to do hidden line rendering. Just select Mental ray as renderer, and load up a preset Toon render in render preset pop up.
Don't mess with my hat !!
Richard McCarthy is offline
Old August 12th, 2004   #4 (permalink)
Chad Warner's Avatar
Or you can use Illustrate! or Vecta3d. If you have Viz4, Vecta came on the second disk (that you probably didn't get, but you can ask your reseller about)
-Chad
Chad Warner is offline
Old August 12th, 2004   #5 (permalink)
India  Send a message via Yahoo to virses
GET ILLUSTRATE! for MAX
If you have FinalRender , it is there.
virses is offline
quick moving red line effect (az la Indie Jones movies)? schmoron13 3ds Max 16 May 17th, 2004 07:18 AM
render hidden line Bret Bullough Autodesk VIZ 5 September 19th, 2003 12:28 AM
Hidden Lines Views Jeff Mottle AutoCAD/AutoCAD Architecture 10 January 16th, 2003 02:15 PM
HIDDEN LINES IN 3D Cesar R AutoCAD/AutoCAD Architecture 3 October 24th, 2002 04:21 PM
Line types STRAT Photoshop 3 June 30th, 2002 01:57 PM
