Autodesk VIZ Autodesk VIZ
Old August 15th, 2004   #1 (permalink)
Fender's Avatar
Philippines
Default Vray render problem... help
Newbie here (obviuosly), im using Vray, Viz4.. then i rendered a test scene below. Using Direct light and Vray shadows checked on transparent and area shadows THEN...
the test scene looks fine except on the edges of the walls and windows, looks like there is a "wash-out", like untidy painting or what.. doesnt look like nice.. you can notice immediately... . HELP! What could be causing this?
Thanks for all the help
Fender is offline
Old August 15th, 2004   #2 (permalink)
kippu's Avatar
Default Re: Vray render problem... help
can you post some settings please ... it will be easier to check what the problem is
its a definite low settings scenario
kippu is offline
Old August 15th, 2004   #3 (permalink)
anvaraziz's Avatar
post ur render settings.....
anvaraziz is offline
Old August 16th, 2004   #4 (permalink)
Fender's Avatar
Philippines
thanks , here are the settings
using 1 direct light, then vray shadows (checked on transparent shadows and area shadows)
multiplier : 2.50
vray shadow parameters : using BOX
U size : 0.2
V size : 0.2
w size : 0.2
Subdivs : 12
low subdivs : 4
degrade depth : 10
GI Vray settings:
using irradiance map
min rate : -3, max rate :-2
clr thresh : 0.8
Nm thresh : 0.5
HSph subdivs : 15
Interp sampes : 25
maybe you will find my setup funny pls correct me if so, im a newbie to vray and please do if you have more suggestions and tips.
thanks!
Fender is offline
Old August 16th, 2004   #5 (permalink)
Name: Alex Ryan Rubio
your hsph subdivs are too low. make it 50, and interpolation 20. give it a try. post an update.
Alex Ryan Rubio is offline
Old August 17th, 2004   #6 (permalink)
Da_RoCk's Avatar
Name: Ramir Lorich Araneta
Philippines  Send a message via MSN to Da_RoCk Send a message via Yahoo to Da_RoCk
Your Nm thresh and color thresh is to high... reduce it... that is causing the artifacts...
MD8 Design Solutions + X3MFXSTUDIOS
Da_RoCk is offline
Old August 23rd, 2004   #7 (permalink)
Fender's Avatar
Philippines
sorry guys for the delayed update... was outta town,.. anyways, i followed all your suggestions and thanks its working fine now, i increased the hsph and interpolations and decreased Nm and color tresh ... thanks the only drawback is its taking too long to render, about 10 minutes, cant imagine if i put all the details in here i think it gonna take an hour... is this normal? anways keep em coming, thanks for all the help
Fender is offline
vray problem Drik Kriagson VRay Render 1 July 9th, 2004 06:21 PM
Vray; Weird Problem - Please HELP stylez VRay Render 7 June 21st, 2004 10:38 AM
Exterior perspecive - vray render voltaire_ira Work in Progress (WIP) 5 June 19th, 2004 03:47 PM
Bedroom - Vray render WIP voltaire_ira Work in Progress (WIP) 9 May 20th, 2004 06:24 AM
Problem with House exterior (VRay) Poco Work in Progress (WIP) 9 April 19th, 2004 05:26 AM
