Old August 24th, 2004   #1 (permalink)
Question looping motion/3dsmax
I want to repeat a simple movement end-to-end over the course of a longer animation in 3ds max 6.0. The reference files point to looping an event in video post, though from a cursory glance this appears to be primarily for render effects. This seems a simple enough task- has anyone any suggestions...?
virtualken is offline
Old August 24th, 2004   #2 (permalink)
abicalho's Avatar
Default Re: looping motion/3dsmax
Do you want to loop a render or do you want to loop an object's animation?
To loop a render you can use Video Post or any other video editing package.
To loop an object's animation, go to Dope Sheet and choose "Parameter Out of Range" - this allows you to specify looping for the tracks selected.
Alexander
abicalho is offline
Old August 24th, 2004   #3 (permalink)
Thumbs up Re: looping motion/3dsmax
The latter- looping an animation. That seems to have got it, cheers.
Old August 24th, 2004   #4 (permalink)
kicks's Avatar
Name: patrick deno desamparado
Philippines
<alex: what happened to the mars rover thingy?
kicks
IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER.
kicks is offline
Old August 24th, 2004   #5 (permalink)
abicalho's Avatar
I just decided to post my picture instead of the Google Rover. You know how it is, I'm single and good advertising helps
Alexander
abicalho is offline
