Name: Jeremy Broom |
I am looking to start a new project of 30 houses in the next 2 months and i am looking to upgrade from lt2000 to adt or Revit but i can not deside on which One could do with some help please.
lLT to ADT!
Please keep in mind before proceeding with the upgrade that both acad and adt have different approach. And the REVIT is tool from 3d parametric modeling approach. I hope you are aware of the change/shift. Please do proper research otherwise. I would go for ADT anyway if i had to upgrade to any of these because of a familiar interface, small learning curve and compatability with other consultants. regards Harjeet Singh |
Name: Russell Thomas |
It would be interesting to know if anyone here is using Revit and how well the models transfer into 3D rendering applications, I will have to go check out whether there is a Revit catagory in the forums. My understanding is that Revit is superior in the parametric modeling and updating of documents, but perhaps not as strong in the construction documentation aspect compared to programs like ADT. Wish I had a crystal ball to see into the future so I knew if Autodesk faded into a Revit based application and faded out ADT such as the case with Engineering Desktop to Inventor. Don't want to bet on the wrong horse! LOL
The Opinions Expressed Here Do Not Necessarily Reflect Those of a Rational Mind. 3DAllusions | 3DAllusions Studio | MrMaterials |
#4 (permalink) | ||
Name: Richard McCarthy |
LOL Scroll down a bit to the "3D CAD SOFTWARE / Autodesk Revit" It translate pretty good to VIZ or MAX and you just need to apply textures to it and fix up some UV problems. http://www3.autodesk.com/adsk/files/..._Revit_VIZ.pdf Yep like you said, Autodesk plans to fade out ADT just like AutoCAD mechanical desktop transition to Autodesk inventor. I think Autodesk has repeated said that Revit is the future, in fact, beginning of this year, they were READY to drop ADT, but somehow market still demands it so they back down and made another version of it and integrate lots of Revit's feature, making ADT easier and more like Revit. But the problem with ADT is that it's essentially is still AutoCAD underneath, so updating engine and it's HUGE limitation due to AutoCAD make it not the wise investment for the future. On the other hand, ADT is more compatible with AutoCAD (ofcourse..) Revit is more like an completely new program (Autodesk acquired it from another company 2 years ago) but it's pretty compatible with autoCAD already. (output to layered files of DWG2004/2000 and DXF) Quote:
That's a myth. You can do documentation FINE in Revit. Infact if you learn to use itl, you would want to draft in Revit through and through. It's a pleasure to draw in Revit than in AutoCAD. But the really, there are endless flamewar and discussion about WHICH to use, I can honestly just offer you the advice of trying out both (can you trial ADT?....with Revit you can) programs and make your own decision. To try out Revit : (download link) or call up autodesk and order a trial CD. http://usa.autodesk.com/adsk/servle...&linkID=3770209
Don't mess with my hat !! |
#5 (permalink) | |
This is from another experience user of both program :
#7 (permalink) | |
Name: Stephen Leworthy |
i use ADT and certainly dont find it a "piece of junk". it's certainly my #1 choice of cad modelling software |
#8 (permalink) | |
Name: Clarence Bricklyne |
I just have only 2 things to say regarding this. Firstly, the person quoted in the post above as an "experience user of both program", by his own admission, both here and elsewhere has NEVER used ArchiCAD. I repeat; By HIS own admission ( even in the above quote)!! Consequently, a lot of what's said about ArchiCAD in that quote, is not only hearsay ( from out-of-context Graphisoft User forum's Wishlists and the like), highly subjective opinons but also patently untrue and considerably misinformed regarding the product itself and its capabilities (specifically regarding stairs and GDL programming). I'm not going to go into any of it here, due to the high propensity of this subject degenerating into a flamewar, other than to agree with the suggestion to visit Graphisoft.com for more qualified information regarding the product itself as well as a demo if you're so interested. Needless to say, to qualify the above would be like implying that based on 3DS MAX users' complaints, the program is horribly unstable and crashes all the time simply on the basis of fragmented complaints of some its users at their forum, when in truth all that the users had asked for was a bit more stability in the program's core. In any case, before I get banned, flamed, or any such thing, just take the above information with a huge grain of salt, and please consider all sources of information carefully in making your decision or considering products. Secondly, IMHO any of the 3 products ( Revit, ADT, ArchiCAD) can be highly productive in any environment, if optimally and effeciently integrated with and based on whatever resources you have at your disposal; and consequently to get into a discussion of which is better than the rest is not only a pointless exercise, but also ignores the fact that it all boils down to which product you're most comfortable working with, and as such, have a personal preference for. Best advice in this kind of scenario; try to get a working demo of each, and if possible run a small project through each of them from start to finish, and use the respective experiences to help you make the decision as to which direction to go. Remember that at the end of the day you're the one that has to live and work with the software after you make up your mind, and someone else's experience will only take you so far. And contrary to what you might otherwise hear, there's no silver-bullet, do-it-all, bug-free, limitation-free solution or software in this or any situation; they all have their own strengths and weaknesses and it eventually boils down to which ones you're willing to work with ( or work-around). |
#9 (permalink) | |
Name: Scott Davis |
Bricklyne - I was very careful in that post that's been quoted here...please tell me how I spoke out of context. I said GDL is not necessary to learn, because some content creation in ArchiCAD can be handled by add-ons, that builds the content (in GDL) for you, but to really harness the power of ArchiCAD, one should learn GDL. Don't you agree? Stairs - Stairs can be built out-of-the-box, but not very complex stairs, correct? It takes an add-on such as Archistair to produce more complex geometries, right? Archistair is free, but still must be "updated" along with the base program as new versions come out to insure compatibility. Other items in my quoted post...well I don't think that any of them are out of context at all. Like I said in that post, I will gladly accept corrections where I have said something incorrectly. Last edited by Scott Davis; November 23rd, 2005 at 11:02 PM. |
Name: maks maks |
hello guys,
Feeling good to get so many views on BIM Techno softwares. For me the transition from autocad/max to revit/archicad was smooth. i work on revit/archicad primarily for modelling purpose. Material,rendering n walkthru i do in max. but yes i find revit all in one and simple. Archicad is time tested stable but yes i do get stuc at times at complx organic forms and let me add we architects r not good in programmin or scripting thing. For complex organic forms i would stark with poly box/nurbs in max n get the shape rather than break my head in revit or archicad. Revit has created a buzz but yes i really dont know what autodesk has in store for us in furure. So plan out well,look to ur needs n then go for it rather than blindly upgrading. Makks Delhi India |
| It looks like my firm is making the switch to Revit. | Spongebob | General Discussions | 16 | October 11th, 2004 06:09 PM |
| ADT Door material | m_cubed | Autodesk VIZ | 2 | August 9th, 2004 04:20 PM |
| Work flow for ADT & Max users? | hieu | AutoCAD/AutoCAD Architecture | 3 | July 4th, 2004 02:07 AM |
| ADT and Max6 | crazy homeless guy | AutoCAD/AutoCAD Architecture | 6 | February 4th, 2004 08:55 AM |
| revit vs. adt | mtutaj | Autodesk Revit | 5 | October 18th, 2003 06:45 AM |
