I have been experimenting with using Photoshop to 'watercolor' filter photos. I don't like the stock WC filter, so I've tried other ways to get a similar result, and recording the attempts in case it actually works.
Here are some tests. #1 is a photo I took, the rest are generic photos. I think these still look more like photos than paintings. I would really like to get them even more 'painted' looking, but still being a single click process. The uses for this would be backgrounds, skies, softening textures used in a model. |
Hi Ernest,
Imho you have too much median filtering all over the image... Try to add it with different values on each channel to beat this. Also an overlay with a highpass filter can do a great job... ;-) rgds nisus |
#5 (permalink) | |
I do use different values on the median, and in the LAB color channels, not RGB ones to avoid neon color edges. I used high values to even out the tones, make them more like a traditional wash rather than try to capture all detail. That is because the purpose is so they can fit into a NPR rendering, not be one on their own. The same for the highpass to generate lines--I figure either the render will not have heavy lines, or I would be using a different technique to generate them, and would use the SAME on as the overall piece so that entourage items match the rendering. |
Name: patrick deno desamparado |
ernest
< I tried but it's not as easy as I thought it would be. Can't get what u have till now.(excellent work on the background trees ). <in how many steps u got it?
kicks IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER. |
#7 (permalink) | |
hehe Well, didnt really record it, as it was a very very quick test to see what ernest didn't like about the original PS WC filter.
My problem with the Photoshop 'watercolor' filter, and several similar ones, is the way that it adds black. In traditional watercolor, black is death. A proper pallette does not have ANY black paint, no grays either. You mix your darks from complimentaries. So when PS adds black (shadow intensity) it ruins it for me.
In reality, dark edges to washes are not black, but more pigment saturated areas of the same paint. Sometimes there is a little mixing with a neighbor. Even though I have a WC rendering or two in my past, I looked at the work of a lot of other people to see how they painted trees, cars and especially people. Common to most, there is a simplification of those elements (from how you would paint them if they were the subject of the picture, and not entourage). So that is part of what I'm seeking to do--simplify. And this is a one-click thing. My recorded action is very long, dozens of steps (maybe 100?), but some of them are un-necessary. I recorded my experiments, so some things I try, then delete, try something else, and it's all recorded. |
| Post Render Experiments... | CGbeginner | Work in Progress (WIP) | 1 | November 20th, 2003 05:17 AM |
| STRAT -- you are needed for medical experiments | Ernest Burden | Off Topic | 1 | May 30th, 2003 02:18 AM |
| NPR Experiments | jucaro | The Unchallenge | 3 | March 31st, 2003 08:01 AM |
