Autodesk VIZ Autodesk VIZ
Old August 31st, 2004   #1 (permalink)
Default Render to Texture
Once again im sorry to keep asking questions, but I've tried finding this out myself but I cant.
What Im looking to do is a bit of texturing. So my presumption would be to use the Render to Texture dialogue box. From my understanding (and common sense) the render button should render out the texture.. but its not.
Now im not sure if im not doing somthing right or if its a problem with my copy of Viz but nothing happens when I do this.
Just as a test I have made a new scene with a simple box in it and ive tried to unwrap that but nothing happens. The Unwrap Only button adds a Automatic Flatten UV's modifier to the stack but I still cant manage to render out that texture.
Any pointers in the direction im going wrong would be helpful.
Cheers
Luke
LukeC is offline
Old August 31st, 2004   #2 (permalink)
mbr
mbr's Avatar
Default Re: Render to Texture
1. Make sure you select what you want to render to texture
2. Make sure you have the destination designated (where the textures will be saved)
3. Make sure you have specified what type of map you want (Diffuse, shadow, etc.)
4. I'd just leave the lower options on the default, or to make a Shell material.
Then hit render! You should see a square window pop up that begins to render the textures, unwrapped (they'll look pretty cool).
mbr is offline
Old August 31st, 2004   #3 (permalink)
Ah cheers, i hadnt selected what sort of map i wanted.
Thanks for that.
LukeC is offline
C4 XL V7 render tips STRAT Cinema 4D 9 August 24th, 2006 01:20 AM
How to render indirect light only Peppi 3ds Max 3 July 12th, 2004 02:33 PM
Road Texture Map P.R.S. Sivakumar General Discussions 9 June 18th, 2004 03:47 AM
Max6:Region Net Render... damn task timeout!!! HarryG 3ds Max 5 February 12th, 2004 12:08 AM
cinema 4d PiNkFlUiD Finished Work 13 February 28th, 2003 05:00 AM
