Name: Kalle Eliasson |
hi all!
Im still using MAX4.2, and Im thinking its time for an upgrade. However... its kinda expensive, so I just wanna check some things with you guys before I throw all my money away. The main reason for upgrading is that I wanna have a better renderer, but the renderer Im most interested in is Vray, and I´d have to buy that one separetly anyway... and it still works with max4. so... what else have happened with MAX during these last releases? Have there been any huge improvements to the modelingtools? Is the "connection" with cadprograms like autocad good now? I know MAX nowadays has fancy stuff like radiosity/GI/skylights and so on, but since I wanna render my scenes using Vray, that stuff doesnt really matter to me? Max6 also has area-lights, but If I buy Vray, Im thinking I could just as well use Vray lights instead? in short: do you think its worth the cash to make an upgrade to max7.0, or could I be just as happy working with my good old release4 and rendering in Vray? Thanks in advance for any thoughts or suggestions! regards Kalle |
Name: jayson giltendez |
if your intention is to use vray as your main renderer, might as well buy the latest version of max (max6, no idea bout max7).. old version of vray is really good, it would be much more i think for its latest version....
thanks jysngltndz n STRAT!
I contacted the people at Chaosgroup, and they said that If I bought Vray for max4 now, I could upgrade/change it to be used with max6 later for free...... so Ill probably buy Vray now, but keep my old Max version for a while... strat: never tried or even seen C4D... Im sure it kicks butt, but I really dont feel like starting from scratch with my modeling right now... learning a new renderer is quite enough =) |
Name: John Dollus |
Not sure why you are so set on Vray but some Max7 features worth noting:
Render to Texture integration now includes mental ray 3.3 – increasing the levels of fidelity available for generating light maps, bump maps, NORMAL MAPS, and even single-map representations of complex procedural and bitmap composites. DirectX Rendering of “Standard Material”: Quickly turn materials used in post production, visualization, and full CG films into game-ready .FX files. Lighting: IES support for indirect lighting: mental ray 3.3 can now render indirect lighting with photometric data from lighting manufacturers and information based on real world units. Automatic photon mapping distribution: Indirect Illumination is improved with an adaptive assignment of photon mapping based on the scene lighting distribution, providing an industry leading global illumination model for film and visualization artists. Controls include: shadows, shadow color and density, projected images, contrast, edge softness, attenuation, and decay. Surface level lighting control with separate ambient, diffuse, and specular manipulation possible. The 2d Lighting Data Exporter saves lighting analysis data as Radiance Picture Files or the .TIF format. Cameras: Precise alignment with either horizontal, vertical, or diagonal field-of-view measure, and support for orthogonal projection. |
thanks John! very informative
The reason I want Vray is that its supposed to be the fastest renderer out there right now. (dont know about MentalRay3.3 though... can it compete with Vray in terms of speed/render quality?) Plus Vray seems pretty easy to learn, compared to MentalRay... Ive worked in VrayFree for a while now, and I love it. another reason, and this is actually pretty important, is that Vray has a very good and active online community... the only thing that really makes me wanna upgrade to Max7 is the IES lights... cant use them in Max4.2, unless Vray lights support IES data...?... dont know. |
Name: Adam Hockley |
If you already know how to use V-Ray, then stick with it. Vray is awesome. I messed with Final Render awhile back, but Vray is so much more better. I think you get amazing and FAST results even at it's lowest setting.....
#8 (permalink) | ||
Name: travis schmiesing |
travis schmiesing |
Name: Stephen Leworthy |
um, you dont. yet. but the boys over at Chaos studios announced their Vray stand-alone plans at this years Siggraph, and it's apparently in the beta testing stage as we speak.
| advice on portfolio | vru | General Discussions | 5 | July 16th, 2004 10:46 AM |
| Need advice - preparing for a CG career | ltravisjr | General Discussions | 7 | July 7th, 2004 12:04 AM |
| need advice | lup | Finished Work | 4 | June 24th, 2004 11:44 AM |
| Need advice related to illustration/rendering | hbryant | General Discussions | 5 | June 22nd, 2004 10:25 PM |
| I need your advice... | dimopoulos_d | Finished Work | 5 | April 21st, 2004 04:28 PM |
