Old September 10th, 2004   #1 (permalink)
Default Displacement problem
We are trying to make our siding appear more realistic, but ran into a small snag. We've created a displacement map to give the siding a 3D profile, the final rendering looks good on the front with the shadows correctly representing the irregularity of the siding. But along the side as you get closer to the ground the siding appears to become flat and no longer has a profile. See red circle.
We are using MAX 6, with VRAY 1.09.03r
Any suggestions would be greatly appreciated.
NeumannHomes is offline
Old September 10th, 2004   #2 (permalink)
wda
wda's Avatar
Name: William Alexander
Default Re: Displacement problem
Looks like a sampling / resolution issue. Have you tried rendering out larger image format, like 2400x1200 for example. Or increase the level at which Vray samples and applies GI to a smaller area unit.
WDA
wda is offline
Old September 10th, 2004   #3 (permalink)
hockley91's Avatar
Thumbs up Re: Displacement problem
Well, despite that problem, your rendering looks very very realistic.
I would say that the displacement problem is a resolution issue also. If the image is at a higher resolution, the farther away part will probably come out clearer.
I had a similar problem with some distant areas as well. I was using Vray, so maybe it's inherent with the GI calculations?
I would like to know how you did your grass? Was that a displacement map also? Please let me know how you did your grass!
Great rendering!
hockley91 is offline
Old September 12th, 2004   #4 (permalink)
Chris Johnson's Avatar
I second that about your grass...
Chris Johnson
Chris Johnson is offline
Old September 17th, 2004   #5 (permalink)
Tommy L's Avatar
Wink Re: Displacement problem
Yeah dude, share your grass. Everyone wants good grass and your grass is definately the shiznit. I may start a 'get Rob to share his grass' thread if your not careful...
Tommy L is online now
Old September 17th, 2004   #6 (permalink)
Tim Nelson's Avatar
If you want that grass, you have to be using vray displacement. You will find that grass mat. easily if you go to the Vray forum and search for grass displacement.
Tim Nelson is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 August 22nd, 2008 05:38 PM
I'm having a problem omar General Discussions 7 June 10th, 2004 09:36 AM
Problem with Asus9800XT and Archicad 8.0/8.1 lschew Archicad 0 May 24th, 2004 10:38 PM
MAX6 MR Displacement Shader wda 3ds Max 1 April 7th, 2004 09:46 AM
