Name: Jorge Tiscareño |
Sorry guys, I almost imagine that this is one stupid question but it has been driving me nuts.
All of a sudden my render image does not appear, I see the render scene bar and the rendering bar too, and I can see the rendering task bar moving but NO FINAL IMAGE! What do I do? You now how the most minor thing can drive you crazy... Thanks for the help as always
"That you are here--that life exists, and identity; That the powerful play goes on, and you will contribute a verse." Walt Whitman |
Name: Daniel Schmidt |
Are you using multiple monitors sometimes and the window is opening somewhere on another screen that you aren't using currently ?
Or could it be hanging around behind the taskbar ? Daniel |
No Daniel, I am not using dual monitors and I checked again and is nowhere to be found.
I was doing the rendering first with Brazil but change to the standard scanline render and I am using radiosity. What now??? |
Maybe Brazil is using it's own framebuffer to show the image and somehow the 3ds max one got turned off. Make sure you have enabled the option for the "Rendered Image Window" (or Show in VFB like it is called in older 3ds max and VIZ versions). The little option should be somewhere below the filename setting for your rendered image.
Daniel |
Daniel thanks a lot, the virtual frame buffer was unchecked, checked it again and finally it appers!
Thanks a bunch!!!
| Printing Resolution/size/dpi/ppi | Jeff Mottle | Tips, Techniques and Frequently Asked Questions | 8 | October 9th, 2008 03:56 AM |
| C4 XL V7 render tips | STRAT | Cinema 4D | 9 | August 24th, 2006 01:20 AM |
| Newbie Question: Is this image difficult to create? | JAVB | Autodesk VIZ | 3 | November 16th, 2003 02:01 AM |
| RENDERNIG - 24in. X 24in. HEL P ! | Cesar R | 3ds Max | 14 | January 1st, 2003 03:49 PM |
