Old September 14th, 2004   #1 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default new RPC trees - 3D or cutouts?
I am having trouble getting the Photoshop plugin for RPC stuff to work. It used to, but I must be doing something wrong.
Anyway, I downloaded the free sample of the new RPC trees to check it out. Can't see it until I solve the above. Are these new trees 3D like the RPC cars, or more like traditional cutouts, with just one viewing angle?
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old September 14th, 2004   #2 (permalink)
Chad Warner's Avatar
Default Re: new RPC trees - 3D or cutouts?
I think the newest RPC trees are just cutouts with one viewing angle.
I remember there was something strange the way the plugin worked--like it didn't install where it was supposed to. I think I had to manually copy the files to the right directory.
-Chad
Chad Warner is offline
Old September 14th, 2004   #3 (permalink)
quizzy's Avatar
The latest collection of trees is a high-res collection, and only have one viewing angle. The images are about 2700 pixels wide if I'm not mistaken...
The 3D trees are on their way!!
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old September 14th, 2004   #4 (permalink)
Thanks, Michiel for the email.
I THINK I have the PS plugin installer properly (I will check by your instructions) it just doesn't seem to want to locate the DLed content.
Yes, it's the 3D trees that I was most interested in. They would be hard to produce, but once done, would be VERY valuable in production.
Ernest Burden III
AcmeDigital
Old September 16th, 2004   #5 (permalink)
quizzy's Avatar
I've seen several examples in animations of the new 3D trees.... one word: AWESOME!!!!!
I'll try to get my hands on one, to see how they work and if my scripts will still work on them.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old September 16th, 2004   #6 (permalink)
When you say 3D, do you mean they work from all angles? Not just from eye-level like the current RPC trees? That would be good....
-Chad
Old September 16th, 2004   #7 (permalink)
Originally Posted by Chad Warner
When you say 3D, do you mean they work from all angles? Not just from eye-level like the current RPC trees?-Chad
That's what I meant.
Ernest Burden III
AcmeDigital
Old September 16th, 2004   #8 (permalink)
quizzy's Avatar
And thats exactly what they are.. The polygon count is more than one.. dont know exactly how many, but at least fewer than every other tree solution. The new ones (that ARE NOT released yet) will have a viewing angle of 360 degrees by 270 degrees... So looking straight up at a tree will not be possible... But who needs that anyway...
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old September 16th, 2004   #9 (permalink)
That will definitely be nice then. One of the bad things about RPC's is that you can't look at them from an aerial viewpoint.
Old September 16th, 2004   #10 (permalink)
I've been using basic X-trees, which obviously have the same problem.
If I know I will have to do a lot of aerial viewing, I could re-design the trees to include a 'top' to help with that, but it;s still not a perfect solution.
Ernest Burden III
AcmeDigital
tip: changing the color of RPC cars plastic Tips, Techniques and Frequently Asked Questions 33 September 24th, 2007 09:42 PM
Trying out plant plugins Gnarly Cranium 3D Tree & Plant Software and Anything Vegetation 26 September 8th, 2006 09:51 AM
RPC Trees Saturn Autodesk VIZ 1 March 20th, 2004 07:39 PM
About RPC stuff kingeldar 3ds Max 5 February 24th, 2004 04:13 AM
script: RPC trees randomizer quizzy Scripts 4 February 24th, 2003 02:49 AM
