Autodesk VIZ Autodesk VIZ
Old September 17th, 2004   #1 (permalink)
Default Importing AutoCAD model into VIZ
I wasn't sure if I should be posting this in the VIZ or AutoCAD forum, but I figured I would get more hits here.
When I am importing a model with numerous curves I always seem to get a number of flipped normals. In CAD I model the general shape in 2d then I make it a region and finally extrude. In VIZ I try to unify the normals but that doesn't seem to work. I am doing this by selecting the object and then in the modifiers panel I selct normals then unify normals. I guess my questions are:
1. Should I be modelling differently in CAD so my normals are unified?
2. Are my steps to unify the normals in VIZ done incorrectly?
ctk111 is offline
Old September 17th, 2004   #2 (permalink)
Default Re: Importing AutoCAD model into VIZ
Yeah I had the same probs with Viz, in time I moved onto Max6 which now makes dxf's look like a 3 year old has drawn them. Not been able to correct this problem I now use exported Illustrator docs which look lovely. Illustrator has known problems not been able to open large dxf files so my solution to this was http://www.dwgconverter.com/ off on a tangent I know.
I know you are importing models. though this may be a useful piece of info for people.
Phew. I love the world of dxf dwg....to be continued, no doubt.
J
Just ask. You never know!
Last edited by JHalton; September 17th, 2004 at 09:12 AM. Reason: Additional text added
JHalton is offline
Old September 17th, 2004   #3 (permalink)
Tim Nelson's Avatar
I model in autocad and file link to viz all the time without many problems. I think you can run into trouble when you start flipping faces, but it sounds like you are mostly solids modeling. Another thing to remember with faces though, is to always make them in a counter-clockwise order.
BUT, I wouldn't really worry about it that much, because in your material options in VIZ, all you have to do is check the box that says '2 sided material'. That will make all objects appear no matter which way your normals are facing. All your problems will disappear!
Tim Nelson is offline
Old September 17th, 2004   #4 (permalink)
Thanks for the posts.
Timmatron:
I'd forgotten about the check 2-sided material box. I can't look at my file to see if that's the problem until I get home. Hopefully that's it. What's up with making faces in a counter-clockwise order? I've never heard about this and is this in AutoCAD or VIZ?
If anyone can think of another possible solution I've overlooked to the flipped faces issue I would appreciate it.
ctk111 is offline
Old September 17th, 2004   #5 (permalink)
Tim Nelson's Avatar
Originally Posted by ctk111
Timmatron:
Here. In autocad, open up the help file. Go to the search tab and paste this in..."Draw Outward-Facing Surfaces and Remove Hidden Surfaces" then hit enter and should bring you to the topic that will explain the counterclockwise thing a little better.
Hope that helps
Old September 17th, 2004   #6 (permalink)
If you are using solid modeling in acad, make sure to UNCHECK unify normals when importing. You would think this should be on to unify normals, but the normals are already correct and this will only screw them up.
Good luck!
mark
Mark Bolin is offline
Old September 21st, 2004   #7 (permalink)
illyrianeye's Avatar
Name: Beni Ecen Vete
United_States  Send a message via AIM to illyrianeye
I have trouble with importing cad models into viz as well. I always get weird shadowy impressions on models for some reason.
illyrianeye is offline
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
Importing from AutoCad designer20103d 3ds Max 2 July 30th, 2004 06:53 PM
importing and uvw map applying autocad model in 3ds MAX j.k 3ds Max 3 May 13th, 2004 11:20 PM
Importing AutoCAD - MAX problems.... Kassner AutoCAD/AutoCAD Architecture 5 May 5th, 2003 06:53 AM
Importing 3DS files to AutoCAD? Matt4 AutoCAD/AutoCAD Architecture 4 March 28th, 2003 07:48 AM
