Autodesk VIZ Autodesk VIZ
Old September 20th, 2004   #1 (permalink)
bully712's Avatar
Question Getting the most out of RAM
Hello,
I just upgraded my RAM to 1.5gb from 512mb. How do I get the most out of my RAM? After installing the memory, I did a few test renderings and it's only using around 400mb. Is there a setting somewhere which allows me to specify how much memory is used by VIZ?
I know this is probably a simple questions for most. I would appreciate any help.
Thanks,
Marc
bully712 is offline
Old September 20th, 2004   #2 (permalink)
bully712's Avatar
Default Re: Getting the most out of RAM
Well I guess it's not that simple of a question. Maybe I have to go to the hardware/technical section
bully712 is offline
Old September 20th, 2004   #3 (permalink)
As far as I know, the amount of ram used only relates to the amount it needs (kind of like gas in a car, only a higher quality gas/ram will make it perform better, not more).
If you want to see a real performance gain, render a very large scene which before required the system to use virtual memory. More ram will also allow multitasking on another program while rendering.
Life Style is offline
Old September 20th, 2004   #4 (permalink)
bully712's Avatar
Well the scene that I did the testing in was that of the Library scene that comes with VIZ. It had raytracing in it, and I thought that it would be a good scene to test. I guess I should render something out with High face count. It would be awesome if you could use all the memory you have regardless of the size of the scene.
Thanks Craig,
Marc
bully712 is offline
Old September 21st, 2004   #5 (permalink)
Saturn's Avatar
Hey Marc, souns like you are upset with your purchase. You will find that the extra RAM comes in handy when you Viz doesn't free up you RAM. There is a way around this, but that is in another thread. I have found that if you want the best performance, its all about the processor (dual, HT, network, etc.). Also, the cooler the RAM runs, the more effective.
-Jason
Jason Matthews
Saturn is offline
Old September 23rd, 2004   #6 (permalink)
Name: Jose' de Castro
British Virgin Islands
Perhaps you could try using some of the ram as a "ram drive" and tell us how it worked. I've heard about it but never got around to trying it. I heard you can place your rendering file in the ram drive and it will be accessed faster thanfrom the hard drive so you can get a speed boost while rendering.
Sorry no link
Island J is offline
afraid of RAM joseph alexander Hardware and Technical Discusions 2 August 26th, 2004 07:29 AM
Virtual ram question Michael Earley Hardware and Technical Discusions 2 May 18th, 2004 01:01 AM
monitoring RAM STRAT Hardware and Technical Discusions 2 March 20th, 2004 11:30 AM
what RAM? STRAT Hardware and Technical Discusions 2 March 22nd, 2003 07:37 AM
