Autodesk VIZ Autodesk VIZ
Old September 25th, 2004   #1 (permalink)
Venezuela
Default about VIZ snaps when working on imported acad plan
For some reason the VIZ snaps only works for some parts of the autocad based drawing, why?
I mean, I drew in Autocad the floor plans of a house, then i file link or import it into VIZ, then Im gonna start creating the 3d model, with a spline, close it and the extrude it, for some reason, the VIZ snaps when drawing the spline, only works on some parts of the autocad drawing, thus making it impossible to draw it correctly, since its not snaping.
Why is that?, i used to draw a wall using the autocad file as floor plan without problems, the VERTEX or END POINT snaps of VIZ will show up on every corner of the autocad drawing, but now, it only highlights some parts of the drawing while not others.
salf is offline
Old September 27th, 2004   #2 (permalink)
mohamedberry's Avatar
Lightbulb Re: about VIZ snaps when working on imported acad plan
i think there is a bug in VIZ when u import a CAD file containing lines, i mean if you make your walls poly lines instead of lines on AutoCAD, then import it to VIZ, it'll work...
mohamedberry is offline
Old September 29th, 2004   #3 (permalink)
Venezuela
Default Re: about VIZ snaps when working on imported acad plan
mmmmmmmmmmm................could it be?.......gonna check that...thanks!
salf is offline
