| Autodesk VIZ Autodesk VIZ |
(maybe we need a Forum for software file conversion ??)
how do you get a 3d model from FormZ into autocad 2004 or VIZ 2005? we have a Client who keeps sending us PDF of EPS files of a Theatre bldg that i end up bringing into autocad (scaling up etc) and Then Tracing over to get some approximate Elevations before trying to reverse-engineer the 3d bldg back into cad and VIZ for rendering (when Then goes into a 2d PS collage) ** There has got to be a more direct way to do This, i Think The bldg keeps changing and it is way too Time consuming to keep re-sketching the Elevations to modfiy the 3d mass modeling any Ideas?? i know This kind of falls into The Cracks in between softwares so maybe There could be a SOFTWARE CONVERSION FORUM for Ideas etc Things like This hey it is only Momday am and i havent had coffee yet so This is my one big Idea for the entire week (since i am NOT familiar with FormZ i am asking here in the VIZ area) Thanks Randy ---- "a Mind is a Terrible Thing to waist." If you dont Mind it doesnt Matter |
Name: Fernando Lino |
Open the PDF fiel in Illustrator and export it to DWG format...There is a program to convert files in different formats...I'll try to find it for you!
#4 (permalink) | |
Name: travis schmiesing |
travis schmiesing |
Name: O. N. Ely |
Hi,
As a long time FormZ user I can say that one of its strengths is that it can read and write almost any file format. I often use 3ds or dwg as required by the nature of the work. See below for a list of formats FormZ can use and take your pick. Good Luck, O 3DStudio ArtLantis DWG DXF FACT IGES Lightscape Lightwave OBJ RIB SAT Shockwave W3D STEP STL 3DGF 3DMF VRML |
hey Fernando
Thanks for the Tip and Technique i (was) mis-informed we do have Illustrator here at work so i will be able to try That later sometime as soon as Time permits Thanks again ** Archidork can you give me a "brief" list of the "exact" commands to "saveas" to Autocad ?? i am sure This is fairly straight forward but i got to send along Instructions to an architectural Principal who does not do This on a day-to-day basis Thanks for your patience Time and consideration ** Randy Last edited by vizwhiz; October 5th, 2004 at 10:05 AM. |
| I need a basic system for ACAD only | jackb602 | AutoCAD/AutoCAD Architecture | 2 | September 23rd, 2004 01:08 PM |
| ACAD Polylines into C4D? STRAT, U there?? | watersage | Cinema 4D | 4 | August 7th, 2004 12:36 AM |
| question for formz users | plastic | FormZ | 3 | May 16th, 2003 11:03 AM |
| FormZ import once more | Radim Blazej | FormZ | 1 | February 3rd, 2003 01:16 AM |
