Name: Joe User |
Well I recently recieved a new machine at work and I come to find out all the settings arn't "standard" out of the box like my old installation was. I have managed to fix everything but one item.
When you select an object and then the move tool I used to be able to put the curser over one of the axis points / or the intersection of 2 points and drag the item around in one or 2 axis at once. well now I can't seem to do that. Where is this button that I have searched for all morning. Thanks in advance, graphix |
Name: Chad Warner |
First thing is hit the "x" key. Second is in the viz ini file, look for the "TransformGizmoRestoreAxis=1" line. If it is set to 0, set it to 1. Either of those should work.
-Chad |
| liquid Modelling question | salf | Autodesk VIZ | 7 | April 14th, 2004 05:41 PM |
| Simple garden planter | DennisB | Work in Progress (WIP) | 4 | March 26th, 2004 09:23 AM |
| Simple Batch Rendering Question? | Andronikos | Cinema 4D | 4 | March 22nd, 2004 12:35 AM |
| Simple animation question! | Andronikos | Cinema 4D | 2 | February 13th, 2004 03:33 AM |
| Simple Wall Texture? | ingo | 3ds Max | 2 | April 15th, 2003 09:47 AM |
