Autodesk VIZ Autodesk VIZ
Old October 20th, 2004   #1 (permalink)
vizwhiz's Avatar
Default linking Plants to follow Camera(s)
hi There
VIZards
i got a whomper project, Phase 1 of 5 or 6 has 1002 Plants
we are using the "bitmap" flat-plane approach so no RPC's
(so far)
how do you set-up the 1st Plant to follow the "current" camera??
There will be various cameras within an Interior courtyard corridor
and some external site-located cameras from also various points of view
and finally i anticipate an animation of all of This at some eventual Time
so This means That The various flat-plane Plants will need to face The Camera
in different directions for the different renders from The different Points of view
i am wanting to do This early and Then clone the Plants following This
b4 putting in Tons of vegie-tation and Then having to re-modify Later
any help would be greatly appreciated
Phase 2, is going to be more than 100 acres, of 220 Total for the Project
so far There is only about 9 different Plants Types
can you modify plant objects "globally" after They are in place to add the "follow camera"
Randy
vizwhiz is offline
