| Autodesk VIZ Autodesk VIZ |
Name: salf none |
I tried searching help within the Ted boarmans tutorials in here, but i didnt find this particular issue (or i missed it)
Im trying to loft a shape along a curved path, the problem is that the lofted shape is lofting "outside" de path. Let me explain it, im doing a curved "sofa", if you see the "top" viewport it should have a "C" shape, so i draw a line, in the top viewport, that describes the "C" curve (path), and then i draw the shape of the sofa, imagine an L type of shape, when i loft this shape on the "C" curved path, it lofts the shape on the outside of the curve, but i wanted exactly the opposite, in the inside of the curve, i have no idea how to fix it, already messed with pivot points and the reference coordinate system, but i cant get it to loft the way i want, am i missing somthing?...please help. thanks. |
Name: Stephen Leworthy |
sound a similar solution to flipping over the shape to be lofted. as described in here - http://www.cgarchitect.com/vb/7500-lofting-crown-molding-3ds-max-6-a.html
Name: salf none |
THanks a lot STRAT, that thread solved my problem, i just had to change the FIRST VERTEX point of the path line, from one end to the other.
| Lofting crown molding in 3ds max 6 | VCRUPI | 3ds Max | 15 | November 16th, 2004 05:38 PM |
| Best method for lofting arches | RyanSpaulding | General Discussions | 8 | July 20th, 2004 03:28 PM |
| Lofting | Sawyer | 3ds Max | 2 | May 7th, 2004 06:44 AM |
| lofting in multiple steps problem | schmoron13 | 3ds Max | 8 | November 21st, 2003 03:54 AM |
| Lofting | Josh | Autodesk VIZ | 1 | July 11th, 2002 07:42 AM |
