Autodesk VIZ Autodesk VIZ
Old October 27th, 2004   #1 (permalink)
Bugga_Guy's Avatar
Default Standard lighting in VIZ 2005
In viz 2005, everytime I start a new project, architectural material is the default material in the material editor. Also when I choose a standard colour and apply it to the mesh (even with no lights) the render seems like it is geared towards a radiosity soloution (giving a bleached look).
Does anyone know how to go back having the "standard" materials as the default material as well having a non-radiosity lighting system as it is in viz 4? I have tried going into the radiosity dialog box turning the "no solution" feature on but still giving that bleached look.
Right now the only solution that works is - I goto my max 4, then setup a quick scene (using standard material) save it and then open it up in viz2005.
Any ideas? Thanks in advance.
Bugga_Guy is offline
Old October 28th, 2004   #2 (permalink)
kippu's Avatar
Default Re: Standard lighting in VIZ 2005
well i am guessing this ...because i dont have viz 2005 ..... but in max 6 if you go to
Customize > Customize UI and defaults switcher > Intial settings for tools > Max
it will go back to standard materials
if it is in design viz then it will become all architectural materials and radiosity solutions
kippu is offline
Old October 28th, 2004   #3 (permalink)
Bugga_Guy's Avatar
Unfortunately I don't see anything about viz standard. Only default viz which it is at now, or default mental ray. I guess its a viz thing.
Old November 3rd, 2004   #4 (permalink)
abicalho's Avatar
Just make sure you disable the Log Exposure Control and your renders should look fine.
-alexander
abicalho is offline
Old December 5th, 2004   #5 (permalink)
Bugga_Guy's Avatar
Talking Re: Standard lighting in VIZ 2005
abicalho - You rock!!
Once exposure control is set to <no exposeure control> volia!! Problem solved.
Many thanks!!
interior lighting haneet khanna 3ds Max 1 April 30th, 2005 04:08 AM
Confused Viz 2005 Elliot Autodesk VIZ 2 October 3rd, 2004 01:16 PM
VIZ 2005, does it have light tracer? chuck Autodesk VIZ 6 May 19th, 2004 05:36 AM
Radiosity & Standard Lighting Sebree Autodesk VIZ 7 November 7th, 2002 03:10 AM
