Autodesk VIZ Autodesk VIZ
Old October 28th, 2004   #1 (permalink)
Default Hiding objects in Viz5 Animation
Is there anyone that knows how to shut off an object on a animation path? I have a object that I want to shut off at the end of its path without stopping the whole animation. I can't locate the option to do that in Viz5. Any help would be appreciated! Thanks!
Buffalo Bills is offline
Old October 28th, 2004   #2 (permalink)
Default Re: Hiding objects in Viz5 Animation
Hi
In Max to can hide an object during animation in track view.
Load Help then type in Add Visibiltiy Track
I take it that its the same for Viz but I have yet to use it.
Regards
BobM
BobM
BobM is offline
Old October 28th, 2004   #3 (permalink)
Bob,
Thanks! I'll give that a try and get back to you! I know Max has a more indepth animation package than Viz so I will search for that.
Hiding Objects in C4D manepalli Cinema 4D 2 November 26th, 2004 10:12 PM
irradiance for animation crazy homeless guy VRay Render 27 August 17th, 2004 05:42 AM
executive wing animation crazy homeless guy Work in Progress (WIP) 30 June 21st, 2004 03:20 PM
animation converter for LS from MAX ??? dombi Lightscape 8 May 26th, 2004 05:37 AM
max script for animated objects data retrival maxscript 3ds Max 0 May 14th, 2004 07:28 PM
