Autodesk VIZ Autodesk VIZ
Old October 28th, 2004   #1 (permalink)
Austria
Default Open Max6 in Viz4?
Hi,
I have one question: Is it possible to open a Max6 File in Viz4 or can I import a max6 File into Viz4.?
I couldnt find any information about this. maybe i just used the wrong words.
thanks in advance
J.R.
J.R. is offline
Old October 28th, 2004   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Open Max6 in Viz4?
you cant. the only thing you can do is export your max 6 model as a .3DS file and import it into viz 4 thataway.
it's a crappy situation in max for down sizing really. in c4d for example you can at least open higher models in lower releases, even if all the features dont work. better than nothing it is.
STRAT is offline
Old October 29th, 2004   #3 (permalink)
Austria
thats what I feared it would be. So 3DS will have to do it. thanks for the quick answer.
J.R. is offline
Old November 1st, 2004   #4 (permalink)
kippu's Avatar
actually theres a script which lets u save stuff and open it in max 5 and even max 4 ....i guess that can help
it is called BACK FROM FIVE script..... if you want i will search and get you the link
kippu is offline
Old November 1st, 2004   #5 (permalink)
if we can't open in VIZ is there a camera correction and windows and doors elements in MAX5 ?
hadasdan is offline
Old November 3rd, 2004   #6 (permalink)
kippu's Avatar
you need design extension for max 5 to get those elements
kippu is offline
dwg to max6 problem alzain 3ds Max 12 September 4th, 2004 10:34 AM
how to open max6 file in max5 bobmaxer 3ds Max 4 June 22nd, 2004 06:19 AM
Any point in Viz4 sans Lightscape dleon 3ds Max 2 April 6th, 2004 01:49 AM
Autodesk VIZ 5 in Production Jeff Mottle Autodesk VIZ 49 October 20th, 2003 11:12 PM
VIZ4 student version salty_dogs Autodesk VIZ 1 January 16th, 2003 02:11 PM
