| Autodesk VIZ Autodesk VIZ |
Hi again
I´ve run into a problem with my Architectural glass and alpha channels. It seems that when i save my image and try to use the alpha channel to map my background into the picture the glass appears as a completely opaque object?!? I don´t know how to work aroun this problem. I have no problem when using a standard material with for example 20% opacity but Architectural glass is so much nicer... What to do?
Regards Ras |
Name: Alex Bicalho |
The architectural material glass has refraction. Refracted transparency cannot have an alpha channel.
Set the IOR to 1.0 and it should have a transparent alpha. Alexander |
Hi Alexander
Thank you very much for your answer. So let me see... I cannot use caustics then - I guess caustics are refraction dependent - right? Also - I´ll loose the nice distortion that glass with thickness produces (like a prism) when IOR is 1, right? What kind of glass do you recommend that I use then if I want to have alpha channel mapping available and still have realistic looking glass?
Regards Ras |
| Architectural Glass in Vray | rozsadan | Work in Progress (WIP) | 12 | August 9th, 2007 05:24 AM |
| Let There Be Architectural Glass | Ernest Burden | The Unchallenge | 60 | April 26th, 2006 08:04 AM |
| Creating Architectural Glass | nisus | Tips, Techniques and Frequently Asked Questions | 20 | November 26th, 2005 03:58 AM |
| Glass opacity | Tommy L | Autodesk VIZ | 6 | March 29th, 2004 11:37 AM |
| Architectural Glass | Jonny English | Autodesk VIZ | 10 | September 18th, 2003 07:42 AM |
