Autodesk VIZ Autodesk VIZ
Old October 29th, 2004   #1 (permalink)
Tim Nelson's Avatar
Default How to reset menus?
On my old machine I only have one monitor now. Unfortunately Viz still thinks I have 2 monitors and all my menus are now out of sight and out of reach. Is there any easy way to get these back?
My only 2 solutions are to either:
a) take one of my monitors from my new system and put it back on the old so i can move the menus
b) re-install viz
I dont want to do either, so if anybody has a good tip, i would really appreciate it.
thanks
Tim Nelson is offline
Old October 29th, 2004   #2 (permalink)
Chad Warner's Avatar
Default Re: How to reset menus?
You can edit the 3dsviz.ini file....look in the viz root folder. There are lines in the file that read similar to this:
[RenderVFBPosition]
Position=52 114
Wherer the position is x and y. Change these numbers to smaller than what they currently are and they will show up on the first monitor.
-Chad
Chad Warner is online now
Old October 29th, 2004   #3 (permalink)
Tim Nelson's Avatar
Dude you rock!
Thats exactly what I needed. Thanks man.
Old October 29th, 2004   #4 (permalink)
That's what I'm here for!
Help..Menus are gone eddie57 AutoCAD/AutoCAD Architecture 2 October 14th, 2004 12:48 PM
max6 hangs when entering dropdown menus.. Eiler Hardware and Technical Discusions 3 August 18th, 2004 03:18 AM
menus on socond monitor klaas 3ds Max 4 May 7th, 2004 04:08 PM
