Autodesk VIZ Autodesk VIZ
Old November 1st, 2004   #1 (permalink)
Default Roof Edge Style Seperate Render Material?
Roof slab, with edge style that incorporates a fascia & soffit.
Once in Viz I can only find option to add material to every part of roof slab.
I want to add a simple white to fascia & soffit. I've found the sub menus that show windows etc as parts ie, glass,frame,muntins, but can not find anything similar under roof slabs.
Advice needed. Do I need to change something in ADT or is their a way I havent found yet in Viz Render?
Al_Zyma is offline
Old November 1st, 2004   #2 (permalink)
davis's Avatar
Name: davis alexander
 Send a message via ICQ to davis Send a message via AIM to davis
Default Re: Roof Edge Style Seperate Render Material?
either setup material by layers in adt or. apply a multi-sub material in viz.
sweet, sweet T&T
davis is offline
Old November 2nd, 2004   #3 (permalink)
Thanks for that!
Got another problem now, still with the roof. I've applied a bitmap of a darkgrey concrete roof tile to the roof layer which thanks to your advice doesnt cover fascia or soffit, but is applied in just one direction throughout drawing! I've played around with the uvw but it just seems to make global changes to all roof slabs. Is there a way to take each slab individually and turn material till its correctly oriented?
EeEEK! I'll get there in the end just upgraded from adt3.3 so Viz render is all new to me!!
Al_Zyma is offline
Old November 5th, 2004   #4 (permalink)
Psychoscorpic's Avatar
Name: Geoff Ward_Able
South Africa
Hi Alan
Continue with the Multi-Sub material: Just add another component (#3), and COPY your material to it. Under the UVW spinners in the material, make the W=90 to turn it 90 degrees.
In the model, select the Faces that you want to have their materials rotated, and assign them ID 3.
This will apply the rotated version of the material to those faces, and the normal direction to the others (#2)
Hope that's clearly described.
Psychoscorpic is offline
Old November 8th, 2004   #5 (permalink)
Yep, that makes sense. Thanks. I haven't used Multi-sub materials yet tho'. I went back to ADT and went into Style Manager> roof slab styles> display properties and changed fascia & soffitt to a layer I defined, then applied a white material in Viz to this layer.
The orientation problem I eventually worked out as been a toggle (auto rendering propergation toggle) that as default was set to on! Once I'd turned this off I could select individual roof parts & rotate materials individually without global effect!
Again thanks for the advice, I will be looking in the help files at multi-sub materials.
Al_Zyma is offline
C4 XL V7 render tips STRAT Cinema 4D 9 August 24th, 2006 01:20 AM
Unable to apply material to Roof/Slab Edge Styles in VIZ Render - Any Tips? eafisher AutoCAD/AutoCAD Architecture 3 May 14th, 2004 10:58 AM
cinema 4d PiNkFlUiD Finished Work 13 February 28th, 2003 05:00 AM
