Autodesk VIZ Autodesk VIZ
Old November 4th, 2004   #1 (permalink)
Default Roofing Tips anyone?
Any tips on roofing tiles anyone?
Mine appear ok in viewport but when I render they all go a soft washed out reddish colour!?!?!?!
Al_Zyma is offline
Old November 4th, 2004   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Roofing Tips anyone?
how about a screeny? you talking about textures or models?
STRAT is offline
Old November 4th, 2004   #3 (permalink)
Thanks for the quick reply.
Textures I think. I've modelled a building in ADT, done the roof using roof slabs with profiles for fascia & soffits. I put the fascia & soffits on a new layer in ADT display properties, this has allowed me to add seperate materials in Viz Render. I've then created new material in Viz using a .bmp of a dark grey concrete roofing tiles. The fascia & soffits render well but the main roof which should appear dark grey is rendering the washed out red coulour?!
Al_Zyma is offline
Old November 4th, 2004   #4 (permalink)
STRAT's Avatar
Wales
post up a screenshot of the problem
STRAT is offline
Old November 4th, 2004   #5 (permalink)
Also I attached 'sitework/paving-ashphalt to path and similar to road. They look ok'ish in veiwport, but get smoothed out on rendering.
Al_Zyma is offline
Old November 4th, 2004   #6 (permalink)
this is the bitmap I wanted to use for roof.
Its not the greatest in the worrld but when Ive used before in ADT3.3 it looks ok.
Al_Zyma is offline
Old November 4th, 2004   #7 (permalink)
STRAT's Avatar
Wales
thats down to your lack of experience.
max is rendering every thing as per normal - as per your specifications and instructions. what you havent done is fine tune your instructions to get the best out of it.
first off you need a bigger map, you need to understand bump mapping, you need you understand the material editor better, you must know about material filter maps and AA filters, you need to know how the material editor works to your advantage. and you must know generally how a render will turn out with reguard to the distance/angle you are from a rendered plain.
as i say, what you've rendered is perfectly expected. you must now fine tune to sharpen things up and get things looking more real.
STRAT is offline
Old November 4th, 2004   #8 (permalink)
You hit the nail on the head re: inexperienced!!
Totally self taught with cad/ADT & now at the beginnnig of the Viz learning curve.
Thanks for the advice, I'll look in depth at the points you mention.
Al_Zyma is offline
Old November 4th, 2004   #9 (permalink)
Name: Ryan Spaulding
http://iws.ccccd.edu/ssutphen/1391.htm
I found this recently. It's a teachers FULL class notes if you need to teach yourself. Note however that this is for 3DSMax...not VIZ....but if I'm correct, Viz is just a stripped down version of Max. You'll find info in here about the material editor.
RyanSpaulding is offline
Old November 4th, 2004   #10 (permalink)
vizwhiz's Avatar
hi There
Al
here is a Link to a List of Links for VIZ:
Main home page:
http://www.viz2000.com
VIZ Tutorials Link:
http://www.viz2000.com/html/link/viz-link.html
Objects Links:
http://www.viz2000.com/html/alfa/alfalink.html
Materials:
http://www.viz2000.com/html/alfa/materials.html
Roof materials:
http://www.viz2000.com/html/alfa/roof.html
CertainTeed roof materials (check This link out):
home page:
http://www.certainteed.com/
roof material photo gallery Index Page:
http://certainteed.com/CertainTeed/U.../PhotoGallery/
example
http://certainteed.com/CertainTeed/U...norShangle.htm
click on Images for larger pictures image:
http://certainteed.com/NR/rdonlyres/.../gm_brwnlg.jpg?
you may need to do some FotoChopping to This
hope This helps
Randy
vizwhiz is offline
RPC or polys, land survey data and other helpfull tips! mhinks 3ds Max 11 November 8th, 2004 07:52 AM
To All Pinoys Working in UAE, any tips please Wendelld Job Board 17 September 30th, 2004 10:07 AM
Tips & freebies page pixelperfectg General Discussions 5 September 25th, 2004 07:46 AM
Unable to apply material to Roof/Slab Edge Styles in VIZ Render - Any Tips? eafisher AutoCAD/AutoCAD Architecture 3 May 14th, 2004 10:58 AM
Any tips for getting RPC ppl walking properly?? marcusl 3ds Max 1 July 29th, 2002 07:57 PM
