Old November 9th, 2004   #1 (permalink)
Cesar R's Avatar
Thumbs up MR help please.. how to improve
Hello guys,
I am trying to learn how to use MR and also keep in mind I havent used max in over a year.. so I am a little rusty. I can get pretty good results with Vray and even the regular advanced rendered but I cant figure out MR.
Can you please take a look at my scene file and tell me what I am doing wrong beside the ugly model? haha
Thank you !
I have used the architecrual mateiral in order to control bleeding which I was able to learn form searching the threads. =)
Cesar R is offline
Old November 9th, 2004   #2 (permalink)
kicks's Avatar
Name: patrick deno desamparado
Philippines
Default Re: MR help please.. how to improve
<Hi cesar, r u using max 7? can't open ur file.
kicks
IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER.
kicks is offline
Old November 9th, 2004   #3 (permalink)
Cesar R's Avatar
yeah... sorry - I am using 7
Cesar R is offline
Old November 9th, 2004   #4 (permalink)
kicks's Avatar
Philippines
<maybe you can try to upload some sreen shots of ur settings.
kicks
kicks is offline
Old November 9th, 2004   #5 (permalink)
Cesar R's Avatar
here is my screen shot.
I was able to get pretty good results, but I had to increase the number of Final gatherings samples from 500 - 2500 for this render.
I am consufed in regards to the light settings in those 3 different places and their relationship. Can someone plese help?
I noticed I get the same effect when I change the Multiples (intensity/color) or when I change the Global Muiltiples (energy)
I hope someone can explain bc the help files arent very well understood sometimes.
Cesar R is offline
Old November 9th, 2004   #6 (permalink)
vertexART's Avatar
Yugoslavia  Send a message via MSN to vertexART Send a message via Skype™ to vertexART
Hi there,
if you change global settings it will affect all lights in the scene... globally.
'Indirect illumination' panel in light properties serves to override global sets for specific light. When you uncheck the 'Automatically calculate....' checkbox, you will enable the lower part of the panel, for local settings.
Now, about the rendering, I think your FG samples and GI photons count are not in a good ratio. With 2500 samples, I think you should increase photons to around 200000, more or less.
Decay is way too small IMHO, nudge it up around 1.7-8, but leave that until the end.
First try to increase FG reflection count to 7, decrease light intensity to 1(always the best result), decrease shadow opacity to around 0.8, and then tweak the energy decay.
Hope it helps, I will look into the file.
Cheers
www.3dcage.com
_____________________________________________
3DSMax8/MR/Vray
vertexART is offline
Old November 10th, 2004   #7 (permalink)
kicks's Avatar
Philippines
>these settings description are according to my MR exerience. Hope this helps
kicks
kicks is offline
Old November 10th, 2004   #8 (permalink)
Cesar R's Avatar
helps very much, thank you !
Cesar R is offline
Old November 10th, 2004   #9 (permalink)
Have a look at the attached file. It gets away with only 200 FG samples, so it renders fairly quickly. Also note the changes made to the materials. Use the photon shader to increase/decrease the bounced light brightness.
Jeff
pixelperfectg is offline
how can I fix these problems? or improve my image? hat-rack Work in Progress (WIP) 2 June 11th, 2004 02:43 AM
how to improve import from architectural modeling apps? Ernest Burden Cinema 4D 27 June 9th, 2004 08:44 AM
Radiosity..where can I improve? pnel77 General Discussions 4 May 15th, 2004 01:48 PM
HELP to improve warwickw Work in Progress (WIP) 25 April 30th, 2004 10:43 AM
can any tell me how to improve this image ishpalsingh Work in Progress (WIP) 6 August 22nd, 2003 07:16 AM
