Old September 3rd, 2003   #1 (permalink)
Hello Guys
I am researching on the theory of radiosity. The way radiosity works and how it calculates and works in softwares like 3ds max 5.
Can anyone suggest me the best place to start out with knowing the fundamentals till all the theory of radiosity.
Kalyan
Kals is offline
Old September 3rd, 2003   #2 (permalink)
choochee's Avatar
Name: Yossi Rachevsky
Israel
Arrow
Try looking at the beginners... LIGHTSCAPE by autodesk. This is the first radiosity renderer I know and maybe they will give you some explanation about their solution.
www.n-trace.com visit us !
choochee is offline
Old September 4th, 2003   #3 (permalink)
'Rendering with Radiance' by Greg Larson and Rob Shakespeare ia an excellent book that goes through many different methods in detail. I highly recommend it from a research point of view.
JD
John Dollus is offline
Old September 4th, 2003   #4 (permalink)
do a search on MIT
there are lots of info in there
.Best Regards
.Nuno
nuno is offline
Old September 4th, 2003   #5 (permalink)
Craig Ramsay's Avatar
Check out the Global illumination and radiosity articles in the resources section of this site!
Craig
www.shakedigital.com
Craig Ramsay is offline
Old September 5th, 2003   #6 (permalink)
jackb602's Avatar
Name: Jack Bransfield
Here are some links I've found very helpful in learning about the theory behind various methods for calculating Global Illumination.
The clearest explanation of the Radiosity method I've found:
http://freespace.virgin.net/hugo.eli.../radiosity.htm
Global Illumination Compendium
http://www.cs.kuleuven.ac.be/~phil/GI/
Henrik Wann Jensen developed Photon Mapping, the GI system used in Cinema 4D, Brazil, and others. This is his home page:
http://graphics.ucsd.edu/~henrik/
Hope this helps,
Jack
Built Light
jackb602 is offline
