Old December 29th, 2004   #1 (permalink)
Maxer's Avatar
Default Dreamscape/Max/& Final Render
Has anyone used Dreamscape 2.1 before with Final Render? I've done some reading on it and apparentley for it to work it must use it's own sky light which might create some problems.
Maxer is offline
Old December 29th, 2004   #2 (permalink)
mbr
mbr's Avatar
Default Re: Dreamscape/Max/& Final Render
I've not used them together yet, but I have read about that. I've also corresponded with some users that said it was not an issue.
I'd go look over the forum boards at Discreet for the Certified Plugins.
I hope to look into this more, too.
mbr is offline
Old December 29th, 2004   #3 (permalink)
France  Send a message via MSN to KiboOst
I've used both together a bit, for landscape in GI and such stuff, didn't had any issue. wat sort of problem could you see ?
| www.kreaction.com |
| www.kiphoto.net |
KiboOst is offline
Old December 29th, 2004   #4 (permalink)
Maxer's Avatar
I'm just trying to decide whether or not to buy it, I've purchased plugins before that wound up not working with Final Render and I want to avoid any problems. I've checked the Discreet forum and it looks like it works with FR so I'm happy about that, and from the two posts I've got here I'm feeling better about it. When you use it with Final Render are the render times slow, and do you have to convert the DS objects into geometry for it to work with FR?
Maxer is offline
Old December 29th, 2004   #5 (permalink)
PiXeL_MoNKeY's Avatar
you can download the demo for DS 2.1 from http://www.turbosquid.com/FullPrevie....cfm/ID/195217
Choose the appropriate download and give it a try.
-Eric
PiXeL_MoNKeY is offline
Old December 30th, 2004   #6 (permalink)
Maxer's Avatar
Ok, I downloaded the demo, it's a pretty complex program but I like what I've seen so far. I tried to animate the clouds but Max kept crashing, I'm hoping this is because it's a demo and not because there is a software problem. I'm going to get it but I've got a questing have any of you used Terragen? Obviousley Terragen is a much cheaper and less capable program, but it does make nice sky's. Is the quality the same or is Dreamscape better?
Maxer is offline
Maxwell, Vray, C4D, Final Render Comparison mbr Other 3rd Party Renderers 4 December 1st, 2004 02:03 AM
final render and RPC alex3d finalRender 3 November 11th, 2004 08:31 AM
Final Render Problems Maxer finalRender 5 November 10th, 2004 08:30 AM
flickering in final render blaz finalRender 8 July 21st, 2004 08:26 PM
Christmas Gift : Final Render Stage-1 Evaluation + Tutorials muzzy 3ds Max 8 January 7th, 2004 09:32 AM
