Name: Bruno Vitorino |
Hy guys, I´m a new Vray user and I´m still trying it, so I´m having some difficults.
Does anybody knows why this rendering was so hard? I used an Athlon xp 2.13GHZ 1GB RAM and the rendering process was so slow. Image size 3189 X 2362 |
Name: travis schmiesing |
read about irradiance maps.
travis schmiesing |
Hi Bruno,
Here is another friendly answer for you. What are the settings for your Vray lights? Are they set as portals? That can increase render time. Also, glossy reflection and refraction can slow things down - is there any of that in there? Also, isn't 10 an extremely high setting for dir comp. subdivs? I've never gone above 3 and even with the preset quality of Very High the dir comp values are only 1:3. Care to show us the final render?
#5 (permalink) | |
travis schmiesing |
Name: Christopher Nichols |
You also seem to be using a LOT of area Vray lights... If you are, even just using area Vray Shadows, try setting all the shadow settings to "Store With Irradiance Map" This will really speed up things, but only if you are doing an Irradiance map, which you are.
Christopher P Nichols |
Hy everyone,
travis,once i tried an irradiance map at a lower resolution, but result was not good; Alicja, thank you I´m gonna try your set up; Fran, thank you, you are so sweet Here are the final images |
Name: michael tang yew |
21:41:01? that is scary, well as they say, Rome was not built in a day, so don't worry, it all has to do with dimension size also, 3189 X 2362 is pretty big, so its a given to expect a long render timeframe...
Distinctly Original site under construction |
| Slow render +15 hours... | Ras | Autodesk VIZ | 5 | January 23rd, 2005 09:21 PM |
| Massive rendering time....am I doing something wrong | Apropos | General Discussions | 15 | October 1st, 2004 08:26 AM |
| mentay ray exterior rendering (unchallenge) | Sirkus | The Unchallenge | 47 | August 22nd, 2004 04:10 AM |
| PURE P1800 Rendering Card | Jeff Mottle | General Discussions | 6 | September 18th, 2003 03:11 AM |
