Name: James Taylor |
i reckon the colours would be altered by what ever took the picture, may have been a traditional film camera which was then printed, maybe left for a period and discoloured before being scanned and then compressed to make a suitable file size for the web.
Also, the lighting conditions that were present when the original image was captured may alter the rgb value of the blue in an image. |
Name: Jorge Tiscareño |
Found this info on the web:
R: 0, G: 10, B: 145 Seems to look right on.
"That you are here--that life exists, and identity; That the powerful play goes on, and you will contribute a verse." Walt Whitman |
Name: Christopher Nichols |
It really all depends on how the scene we lit... It really does not matter as long as it is almost all green or almost all blue. Most people use green nowadays since you can key it better from Video. But color does not matter as much as lighting... that is the key (pun intended).
Can you tell us why you need to know? If you are trying to make your own green screen there is a lot you may need to know about....
Christopher P Nichols |
Name: Tom Livings |
I was seperating an RPC pass in Viz. The PRCs occasionally went behind elements on the scene so I applied a matte/shadow material to everything and made the background blue. This was so i could use the bluescreen setting in Premiere. I just wondered if there was an ideal blue that evryone uses. Turns out that it picked up the boundaries fine though.
Thanks for your help guys. |
Name: Chad Warner |
Tommy-
Since you were successful in getting the RPC's to bluescreen correctly, can I ask you a couple questions?: How did you deal with the "halo" that ends up being around the RPC from the transparency? What about the shadows? This is where I don't know how to deal with the green screen or blue screen method....the shadows always pick up the color of the background. Thanks, Chad |
#8 (permalink) | |
All compositing software that 'color keys' into an alpha mask works in a similar fashion, takes the 'color' value (rgb) and creates a greyscale based alpha mask from that value. So the greater the difference of value between the scene elements and the 'bluescreen', the highr quality mask. WDA
| NCS colors to RGB??? | skogskalle | General Discussions | 2 | December 9th, 2004 08:21 AM |
| RGB Colour of the Sun | JHalton | General Discussions | 4 | December 7th, 2004 09:14 AM |
| TIP: RGB value calculator | quizzy | Tips, Techniques and Frequently Asked Questions | 6 | March 21st, 2004 09:21 AM |
| PANTONE colors - Need RGB values for VIZ | Eric | General Discussions | 3 | October 12th, 2002 09:00 AM |
| rgb file | PI | Lightscape | 0 | July 13th, 2002 08:39 AM |
